where is the FUSE on the ebay fog lights 99-00
hey i got an em1, my foglights went out and i cant seem to figure out whats wrong, i want to check the fuse but does any1 know wher ethe fuse is located? thanks
btw, i relocated the ground near the driver side fog light to a different part of the chassis, and it worked (only the driver side worked), earlier i turned on the switch and neither of the lights work again so i think it might be the fuse. thanks
Re: where is the FUSE on the ebay fog lights 99-00
actually theres an update, i re routed the ground wire again and now my driver side fog works again. but i sitll need to know where the fuse is. thanks
Well if one fog light is working then it's prolly not a fuse, Does your wireing have two grounds on it? One for eatch fog light? if so try re routing the other ground.
I8ayellowcrayon
21
09-01-2005 01:34 AM
