Broken slave cylinder bolts
Old Mar 25, 2023 | 09:18 PM
Craterh's Avatar
Default Broken slave cylinder bolts
Hello everyone,
My clutch makes a lot of squeaking noise when pushing the clutch pedal in. I figured this is related to the metal on metal contact within the slave cylinder itself.
So I go to remove the slave cylinder, and the two bolts that hold the flange to the firewall are broken inside of the threads, and everything is painted over.
I tried accessing the rod from behind the dash (taking the pin out, the snap ring, and all that), but I only got to a cone shaped piece that wasn't the issue. I put that back together.
My question is, how do you extract a bolt that has less than a foot of clearance? The slave cylinder is directly behind the strut tower, so theres no way to get a drill in there. Is there another way to lubricate that mechanism to stop the squeaking? Any advice or input greatly appreciated.
Old Mar 26, 2023 | 09:01 AM
Chrisfrom1986's Avatar
Default Re: Broken slave cylinder bolts
It's mounted from the inside.
Old Mar 26, 2023 | 10:40 AM
Craterh's Avatar
oh my gosh you're a lifesaver
Sorry if that was a stupid question I've never owned a manual before thank you so much
cl9 jon
Acura TSX
Feb 10, 2014 04:17 AM
dtran002
Jun 12, 2013 10:12 AM
bandit080000
Jun 4, 2009 05:28 AM
importfanatic17
Jan 2, 2007 02:31 PM
cdx280
Jun 15, 2006 10:36 AM
