evap wiring issue 00 civic HX
Old Feb 25, 2023 | 12:18 PM
puffthrax's Avatar
Default evap wiring issue 00 civic HX
i need some help, bought this car off marketplace and need help with wiring, car is a 2000 civic HX. it was swapped with a d16y5 with a y7 harness and p2e ecu. car is wired good to where it runs fine but i have been getting a p0452 and p0450 code for evap. i replaced the canister 3 times and even the FTP. still no fix. i took a multimeter to the plug and wasn’t getting any signal from the plug. there is also which looks to be another evap plug off of the green cabin harness which could have been the actual plug for it. i plugged it in and still no fix. there was also no power from that plug either. so what i’m tryna figure out is if the plug i need for the VSV is on the actual engine harness or on that green cabin harness that sits in front of the ECU. kinda lost and not sure what to do
GrimLude
May 13, 2014 11:24 AM
asigler
Jul 22, 2009 10:59 AM
Project_SOHC_EX
Jul 4, 2006 04:57 PM
rossc96
Feb 12, 2005 07:01 AM
Wazup
May 6, 2003 10:03 PM
