95 civic dx b16a motor idle air control valve
Old Feb 21, 2023 | 02:49 PM
Spaz253's Avatar
Default 95 civic dx b16a motor idle air control valve
Son's hose keeps coming of idle air control valve think we need new hose, do I ask for 95 civic or 97 integra IAC valve ? He might replace iac valve also. Let me know thanks
Old Feb 23, 2023 | 09:44 PM
MorningStar★'s Avatar
Default Re: 95 civic dx b16a motor idle air control valve
It sounds like you may need a new hose for your idle air control valve. When it comes to the IAC valve itself, there are a few different options to consider. The 95 Civic and 97 Integra both have different part numbers for their IAC valves, so it's important to make sure you get the right one.
To find the correct part, you can try looking up the part number for your son's specific car based on the year, make, and model. Another option is to take the old IAC valve to a parts store or mechanic and ask them to match it up with the correct replacement.
Once you have the correct IAC valve, you should be able to install the new hose and get everything running smoothly again.
Old Feb 23, 2023 | 11:24 PM
Spaz253's Avatar
My son has a 95 civic dx with a b16a motor, so idk if I need one for a eg or from and integra ? Also trying to track down a hose but no one seem to know what it is do u know what it's called or the part number ? I asked for a iac hose and they didn't know what I was talking about. Thanks for ur response
Old Feb 24, 2023 | 08:09 AM
spAdam's Avatar
Loved
Community Favorite
Assuming it's a USDM B16A2 or similar, you'll want to look up parts for a 94-97 Del Sol vtec. Dealer is your best bet. A parts store s just going to sell you a length of hose.
Old Feb 24, 2023 | 10:32 AM
it's possible that it may be called something different than what you're used to hearing. You can try searching for "idle air control valve hose" or "IAC valve hose" for your specific make and model. Another option is to take the old hose to a parts store or mechanic and ask them to match it up with the correct replacement.
Once you have the correct parts, installation should be fairly straightforward. There are plenty of online resources and forums that can guide you through the process step-by-step, but if you have any questions or issues, please feel free to reach out
Old Feb 24, 2023 | 12:39 PM
Spaz253's Avatar
I think I might have tracked it down it's EAC not IAC?
Old Feb 24, 2023 | 12:45 PM
Spaz253's Avatar
just asked my kid it's jdm b16a I added pics for the hose to the thread if u wanna see if its the rite one
Old Feb 24, 2023 | 02:19 PM
spAdam's Avatar
Loved
Community Favorite
Should be the same unless it's a really old 90-91 B16A, then you'd have another set of headaches.
WHen you say the hoses keep popping off, are they clamped place?
Old Feb 25, 2023 | 02:40 PM
Spaz253's Avatar
yes there is a little ring around it with a screw to tighten it, the other end of the hose leaks a little . He thinks the hose is to short or something. The car does vibrates like crazy that could be it to idk. I called AutoZone they said they don't carry that to call of dealerships so I called the Honda dealership they said it's discontinued so there's no way to order that hose
Old Feb 25, 2023 | 02:43 PM
Spaz253's Avatar
Honda dealership said its discontinued so no way to buy a new one, autozone said i wouldnt be able to find one either
Old Feb 25, 2023 | 08:54 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Just buy some 5/16" fuel injection hose (and I know what you are thinking, he meant to say heater hose, and that would work also, however, FI hose will likely be the same size as the original hose so you can use the factory clamps) and create some loose bends to make the needed connections. Otherwise, you will have to purchase some small worm gear clamps at the same time.
Old Feb 26, 2023 | 12:56 PM
Spaz253's Avatar
Ok great thanks, that was gunna be my next post to ask what else would work lol.
Old Feb 26, 2023 | 01:03 PM
Spaz253's Avatar
Item Dimensions 4.6 x 3.1 x 1.5 inches for the iac valve hose
Will the 5/16 hose still work
Old Feb 26, 2023 | 07:32 PM
JRCivic1's Avatar
10 Year Member
Community Builder
If you can get the OE part... get it. If not, go to your nearest auto parts store for some 5/16" fuel injection hose. Take a piece of the damaged hose with you to compare OUTER diameter. If the new hose is the same size or VERY SLIGHTLY larger, then you should be good.
Old Mar 6, 2023 | 07:43 PM
Spaz253's Avatar
just wanted to say thanks again the 5/16 fit perfect. I really appreciate ur help.
Old Mar 6, 2023 | 08:33 PM
JRCivic1's Avatar
10 Year Member
Community Builder
I am always glad to assist.
Spaz253
10
Oct 10, 2022 09:18 PM
93HkSIcherry
Sep 28, 2022 05:01 PM
BDWebb
Nov 3, 2020 05:10 PM
ShatiaNichols
Jan 31, 2012 08:15 PM
