Really Confusing Electrical Issue Please Help
Old Jan 23, 2023 | 06:37 PM
MechUnion's Avatar
Default Really Confusing Electrical Issue Please Help
Whenever the car is receiving power every single light in the cabin will randomly go out for no reason, except the handbrake, turn signals, and some other dash warning lights; those never go out.
Then sometimes they turn back on randomly if I smack the dash near the dimmer switch, hit a bump, or sometimes they just come back on while driving for no reason at all.
I visually inspected what appeared to be the correct fuse several months back and it didn't look blown. This issue has been going on for ages and I'm sick and tired of it.
Any help would be greatly appreciated.
Old Jan 24, 2023 | 07:05 AM
Relic1's Avatar
Default Re: Really Confusing Electrical Issue Please Help
which chassis/trim do you have? this sounds a lot like a ground issue.
Old Jan 24, 2023 | 09:39 AM
MechUnion's Avatar
It's a 99 LX.
Old Jan 24, 2023 | 03:26 PM
crazyhorse2011's Avatar
10 Year Member
Loved
pull off all your grounds and clean them, retigthen
Old Jan 24, 2023 | 10:10 PM
Chrisfrom1986's Avatar
Obviously the dimmer switch.
Old Jan 25, 2023 | 03:51 PM
MechUnion's Avatar
What makes you think it's the dimmer switch? It functions totally normally whenever the lights decide to turn on.
Old Jan 25, 2023 | 06:51 PM
Dimmer switch powers the lights in the cluster. Unplug it and you'll see they don't work.
Old Jan 26, 2023 | 01:12 PM
Relic1's Avatar
they did not read your post closely.
if you only mentioned the dash lights I'd agree. but since the interior lights are included in your original statement, it has to be a ground under the dash. or a fuse that's not properly seated or the connections are burned.
Old Jan 26, 2023 | 07:51 PM
Maxcapacity's Avatar
Check fuse #43 for the lights it's a 7.5amp, remove and reinstall it.. could have a poor connection.
headrec*
10
Jul 15, 2008 10:35 PM
ilovemydc5
May 22, 2007 12:45 PM
ziggen243
Sep 22, 2005 11:17 PM
Imadisgrace
10
Jan 28, 2005 01:09 AM
goku28
Jul 16, 2004 02:57 PM
