ITR fuel pump vs Civic B16A fuel pump
I don't have flow data, although RC Engineering should since they do pump testing all the time. They did the volume vs pressure test posted on Hondata's site. That one was from a Civic Si, which would be the 'big' Honda pump.
Let's just say it's enough of a difference that Honda felt to put the higher flowing pump on the other cars vs the standard EG pump. And that's just bone stock cars - you will find that on modded cars the EG pumps lean out because they can't keep up with flow. And for FI I wouldn't even consider the stock Civic pump.
Also, I forgot to mention that I am almost positive CRVs use the higher flowing pump. I have not verified it personally, but I know a lot of people that do B20 swaps into an EG has flow problems with the stock EG pump.
Personally though, if you have a Civic pump and were considering getting the higher flowing Honda pump, you may as well get a Walbro 190LPH pump for $70 which will be plenty of flow for just about anything short of wild FI setups.
- Slater
[Modified by Slater, 6:19 PM 11/20/2002]
- Slater
92-95 EG vs ITR pump
how much stronger is the ITR bump vs the eg pump?
with dohc vtec
Correct...when I said EG I meant SOHC.
B-series DOHC VTEC/DOHC non-VTEC pumps are the 'big ones'. So anything Honda stuffed those into got the big pump. EG2 (I already mentioned), EG6 etc.
Stephen, have you been able to verify a CRV for sure?
- Slater
- Slater
Black R
Mar 6, 2004 12:05 AM
Charlie Moua
Jul 11, 2002 12:28 AM
-Darren-
13
Mar 15, 2002 11:44 AM
