h22 4p alt to 3p harness
Old Jan 4, 2023 | 11:12 PM
evxile's Avatar
Default h22 4p alt to 3p harness
hey guys first time posting here was wondering if i could get some help from you guys. i recently bought a budget harness for h22 to "ek" from jackspania but they sent me a harness with an alt plug with only 3 connections but my alt (circle plug) has four pins was wondering if you guys can help me figure where to wire the 4th cable in or if they make a 3 pin alt? or does it not matter? harness is obd1 i believe thanks i appreciate the help
(ill upload pics if needed)
Old Jan 5, 2023 | 10:00 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: h22 4p alt to 3p harness
Lots of aftermarket engine harness builders do NOT place the ELD wire into the alternator plug... so if you want to add it, you can do so. You can also simply turn the ELD circuit off in the ECU if you have a tunable solution (like Hondata S300) and you will not need to add the wire to the plug.
Old Jan 5, 2023 | 10:47 PM
evxile's Avatar
ah okay i didn’t know that ! what if i don’t have a tunable ecu? can i run the car normally or would i have to pin it in ? and if i do have to pin it where does it go to? THANK YOU so much for the help i appreciate it !
Old Jan 7, 2023 | 01:26 AM
JRCivic1's Avatar
10 Year Member
Community Builder
It is not that simple. You will need a FSM to properly wire the ELD circuit because it is extensive.
da59block
Nov 13, 2011 09:42 AM
turbogsr18
Apr 28, 2008 01:18 PM
turbogsr18
Apr 28, 2008 11:10 AM
h-duced
Jan 17, 2008 03:27 PM
civichb97
Dec 9, 2002 01:22 PM
