Car wont turn over and have no idea how to trace it
Old Dec 15, 2022 | 12:55 PM
Ved9o's Avatar
Default Car wont turn over and have no idea how to trace it
Hi, I have a 98 civic Lx sedan and ive been having issues with it not turning over. The starter wont even do anything when i turn the key. i went and had the starter tested and it works just fine and i replaced the starter relay. when i turn the key the coolany radiator fan runs but nothing else relating to the starter works. I just relpaced the battery as well and all the connections look good. does anyone have any ideas on what it could be?
Old Dec 15, 2022 | 04:21 PM
Jack Gorlick's Avatar
Default Re: Car wont turn over and have no idea how to trace it
Check the ground from the battery to the chasis
you can actuly hook it up to another car with cables and it will ground there insted
Old Dec 15, 2022 | 04:23 PM
Ved9o's Avatar
ill be sure to try that and ill get back to you soon
Old Dec 15, 2022 | 04:25 PM
I got one from autozone and just grounded it anywere You can try scratching it up were the bolts at the chassis
Old Dec 16, 2022 | 08:01 AM
Sic_DA_Nine's Avatar
is the car all stock?
does it have an aftermarket alarm system?
have you tested the ignition?
Old Dec 16, 2022 | 08:18 AM
Ved9o's Avatar
It just has an aftermarket intake and it is wired to have an alarm system but they are unplugged and im going to test the ignition system for proper power today and make sure everything is getting 12 V
Old Dec 16, 2022 | 08:21 AM
Chance EG's Avatar
Do you hear the fuel pump prime when you move the key to the second position?
Old Dec 16, 2022 | 08:25 AM
Ved9o's Avatar
Yes the fuel pump is all good
Old Dec 16, 2022 | 08:50 AM
Ved9o's Avatar
i tried the ground and it didnt work
Old Dec 17, 2022 | 02:48 AM
wunfstgsr's Avatar
Loved
Community Favorite
Sounds like a bad fuse, I can't remember the number of the fuse to check but make sure all fuses are good! start with the one in the engine bay and make sure the battery fuse didn't blow. Then check all fuses in the fuse box inside the cabin.
Old Dec 17, 2022 | 07:43 AM
Hey what about the clutch safty switch/netral saftey switch you can ground them bolth look into it
Old Dec 17, 2022 | 08:58 PM
wunfstgsr's Avatar
Loved
Community Favorite
Good idea!
Old Dec 20, 2022 | 03:41 PM
Ved9o's Avatar
I have an automatic
Old Dec 20, 2022 | 03:43 PM
Yeah autos have it to
Just stick a wire in it, easy
netral safety switch shold do it, look into it
Old Dec 20, 2022 | 03:45 PM
Ved9o's Avatar
Im trying the ignition switch but after that i will try that if it doesnt work, seriously thank you guys for the feedback, i have no idea what im doing
Old Dec 22, 2022 | 09:35 AM
Stock95delsol's Avatar
Check the switch under the clutch peddle. add another ground to your battery. make sure that you're pushing the clutch all th eway in .
Old Dec 22, 2022 | 09:37 AM
Its auto
Ved9o's Avatar
I have a A/T
Old Dec 24, 2022 | 08:54 PM
I dont know what the link are to these forms
did you figure it out.. thats the place you put a wire in a U shape
Old Dec 24, 2022 | 09:00 PM
Also i think you can wire the starter
im not 100 % how
but probly
Key to on position
- to +
all on the starter
(At least thats how i got my truck to start at work every day)
And you got it tested right at like autozone? mabe time for a second opinion
Old Dec 31, 2022 | 12:54 PM
Ved9o's Avatar
little update ive replaced the entire circut not including the starter because i had it tested 3 times and it was good and all the fuses so should i replace the fuses?
Old Dec 31, 2022 | 03:18 PM
did you try to jump the starter relay with a hand-held remote starter switch? that'd tell you what you need to know.
Old Dec 31, 2022 | 03:25 PM
Ved9o's Avatar
yes and that works
zombieD
15
Sep 26, 2008 11:48 AM
blueb16-em1
Jun 19, 2008 05:12 PM
716pro
May 15, 2005 09:22 AM
EF9 JAMS!!!
Sep 23, 2004 10:21 AM
