92 Civic EG - Best AC Option
Old Dec 12, 2022 | 08:45 PM
B00STD's Avatar
5 Year Member
Loved
Community Favorite
Default 92 Civic EG - Best AC Option
1992 Civic eg hatch with B16
What compressor setup is best? I believe starting with the R34a AC setup is best from prior knowledge which came in later years?
From there, should you go with the civic or integra compressor? Is the civic compressor lower output but lighter?
Does the B20 AC bracket work on B16 I’ve heard it may have clearance issues and the Del Sol VTEC 94-95 bracket (for a B16) is preferable?
Old Dec 13, 2022 | 02:10 PM
DaX's Avatar
DaX
Loved
Community Favorite
Default Re: 92 Civic EG - Best AC Option
I would do an R134a system and use the TRS90 compressor with the DelSol VTEC AC bracket. Not sure about the B20 bracket.
I'm not sure what condenser came in the EG chassis with the R12 system - if it's a serpentine flow condenser, you'll definitely want to change that out to a parallel flow for the R134a. Clean out the system to remove the mineral oil and use PAG 46 oil.
Old Dec 13, 2022 | 03:10 PM
punk0mi's Avatar
5 Year Member
Loved
Community Favorite
The problem with the EG civic AC system wasn't the compressor...it is the woefully small condenser. As @DaX mentioned, get rid of the serpentine condenser and get the parallel flow.
When I rebuilt my EG, I put in a Denso/Sanden TRS090 brand new...NOT a reman. I got a line set from a 95 Civic that used R134A. Cleaned them thoroughly and dried them. Replaced the entire evap coil and expansion valve..so it was essentially a brand new, dry system. A heads up, the Integra units used a 10PA15C style compressor. These will work on a swap, but will require additional work with the line set as they aren't exactly plug-n-play with EG lineset.
The B20 (P7J) bracket will fit on a B series and mount D series compressors...however, the clearance between the frame rail and the mount stud don't exactly play right (At least on mine it doesn't..i don't have it connected to the frame there and it does kind of bother me).
Old Dec 13, 2022 | 07:52 PM
B00STD's Avatar
5 Year Member
Loved
Community Favorite
Thanks guys. Looks like the trs090 compressor fits a lot of Hondas.
Old Dec 14, 2022 | 11:07 AM
B00STD's Avatar
5 Year Member
Loved
Community Favorite
Ok…throwing you guys a curve ball now!
Lets see how good you are!!
We talked about the B20 mount, and the Del Sol mount…how about the VX model aluminum AC mount “P07” will that fit a B16 in a EG Hatch?
Old Dec 14, 2022 | 01:58 PM
DaX's Avatar
DaX
Loved
Community Favorite
I don't think so. I believe the bolt pattern for the block is the same as other D-series. This one is just lighter because it's made of aluminum.
Old Dec 15, 2022 | 01:09 PM
B00STD's Avatar
5 Year Member
Loved
Community Favorite
Yep I think so…probably bolts to D series. I’ll stick to the Del Sol bracket
Old Dec 17, 2022 | 07:22 AM
punk0mi's Avatar
5 Year Member
Loved
Community Favorite
No. I feel 99% sure that the P07 is for a D series engine only....then again, I know i've made mistakes before lol
The only Del Sol bracket I know that worked on a B series with D series compressor was a P54 that came off the Del Sol VTEC (which had the B16).
epingquian
Apr 3, 2018 07:56 PM
SpiderBall
May 3, 2008 04:38 AM
DJNauTicz
10
Aug 4, 2007 12:48 PM
jdmeg9
Jun 7, 2005 02:11 PM
