Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Drum wheel cylinder
Old Nov 29, 2022 | 05:15 PM
Nayvelli's Avatar
Default Drum wheel cylinder
I have a 2002 civic and the drum brake wheel cylinder piston keeps on popping out. I bleed the brake and it’s find. But as soon as I turn the car on and step on the brake I lose pressure and it pops out. Mind you i went through 2 bottle of brake fluid to make sure all the bubble were out. I need help. I was think the brake booster or master cylinder but I have no idea
Old Nov 29, 2022 | 06:10 PM
DCM1's Avatar
Default Re: Drum wheel cylinder
How tightly does the drum fit over the shoes?
Old Nov 29, 2022 | 06:33 PM
Nayvelli's Avatar
It’s pretty snug and I forgot to mention I changed the hardware and brake pad at the end of the summer
Old Nov 29, 2022 | 06:38 PM
DCM1's Avatar
Looks almost like it’s too short. Have you compared the wheel cylinder length between that and the other side?
Old Nov 29, 2022 | 07:44 PM
Nayvelli's Avatar
No that I think of it I have not
Old Jan 4, 2023 | 05:42 AM
Prune's Avatar
Was the drum on and over the studs before you bled the system?
Also, check the other side as the wheel cylinder may go into the shoe recess, the shoes need to be raised.
jfboy
Dec 6, 2019 10:07 AM
5rivers
Oct 10, 2015 06:44 AM
limpy
Mar 4, 2006 07:13 PM
Built B18ABorC
Oct 24, 2004 08:23 PM
teger
Jul 31, 2002 02:27 AM
