radiator fluid leak help
Old Nov 18, 2002 | 04:28 AM
deftones0817's Avatar
Default radiator fluid leak help
Car is running hot when he is driving it then its normal again two minutes later....its leaking out a little radiator fluid on passenger side of car....what could it be? If he don't add more it doesn't leak but if he adds more it just leaks back out. The radiator fluid is still on the high side even if he doesn't add more but i won't leak anymore.
let me know if you have any ideas.
DEF
Old Nov 18, 2002 | 01:46 PM
Default Re: radiator fluid leak help (deftones0817)
ttt
Old Nov 18, 2002 | 01:53 PM
Leb_CRX's Avatar
if I read correctly, check and make shure the plug at the bottom of the rad on teh pass side is TIGHT...cause that's the coolant drain plug, could be lose...
otehr than that might be a hose..get the bitch real hot and open the hood an see where the smoke's coming from
|eb_CRX
Old Nov 18, 2002 | 01:56 PM
Default Re: radiator fluid leak help (Leb_CRX)
thanks ill try that.
DEF
eruktion
14
Aug 21, 2009 01:33 PM
skata89
Oct 2, 2005 04:38 PM
tca0bell
Mar 23, 2005 01:09 PM
TJ R
Jan 20, 2003 09:44 PM
Turtle
Jul 19, 2002 12:10 PM
