New Transmission No Start
Old Nov 23, 2022 | 12:33 PM
ronisdb's Avatar
Default New Transmission No Start
I just put back in a transmission in my 2000 Integra LS Skwa auto with a used skwa. Got everything in and went to start and it cranks but no start. I have no spark. My key light doesn’t light up neither does my cel/mainreq and oil light when i have the key turned. Had the car sitting for a little over a month
Checked Fuses
Check Ground
Neither can I connect my obd ii scanner
Can’t hear fuel pump turn on
When I have the key turned it is stuck in park but I can use the shift lock and press it down and can move it but ever gear lights up besides D4
Old Nov 24, 2022 | 05:58 PM
wunfstgsr's Avatar
Loved
Community Favorite
Default Re: New Transmission No Start
Have the battery checked/ re charged.
Old Nov 25, 2022 | 10:50 AM
Maxcapacity's Avatar
Did you happen to remove the harness ground from the thermostat housing? That MUST be on. If your getting good cranking your battery is probably fine because if it was low on charge you would have weak cranking or clicking coming from the starter.
Also, with your shifting trouble, are you pressing the brake pedal so it can shift with key on but the car not running?
4 door beast
Feb 25, 2010 04:35 AM
billy hoang
12
Apr 11, 2009 07:54 AM
nemeii
23
Aug 10, 2008 03:10 PM
Polando83
Jul 11, 2005 05:11 PM
98cwtypeR
Sep 24, 2002 08:53 PM
