Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
2002 Civic DX: Never ending air in brake lines
Old Oct 27, 2022 | 07:34 AM
hondadrivingman's Avatar
Default 2002 Civic DX: Never ending air in brake lines
I replaced two brake lines going to the cylinders on the two rear wheels. I also replaced the left rear brake cylinder. I made sure the rear drum brake was adjusted so it was slightly scraping when I spun the wheel . I think I let air get into the system when I did this work. The problem is the brake pedal goes all the way to the floor and I keep bleeding the air from the brakes and every time I do, more air comes out. It seems there is never ending air coming out. Does anyone have any ideas?
Old Oct 27, 2022 | 10:32 AM
DCM1's Avatar
Default Re: 2002 Civic DX: Never ending air in brake lines
What's your procedure for bleeding them?
Old Nov 6, 2022 | 02:38 PM
I've done it starting from the farthest wheel working towards the master cylinder and then also starting closest to the master cylinder and working away from it. I have blead them like 6 times.
daboy155
Suspension & Brakes
Mar 13, 2016 05:19 PM
blu3g
Apr 22, 2006 10:36 AM
JDM_EK_JOE
Apr 14, 2006 11:44 PM
tilt
Mar 11, 2003 08:52 PM
wessieball
Aug 4, 2002 07:47 PM
