Turn signals light up but won’t blink
The only thing I did was do a wire tuck and cut some of the abs wires and srs ones and sealed with electrical tape.
Turn signals were working fine before this. The back signals blink but fast and the back hazards blink, the front is illuminated but no blink from the signals or hazard
Replaced hazard switch and turn signal relay with known good ones. I’m getting battery voltage to both as well. Cleaned g201 ground on the fender frame rail since I tucked and grinded it to bare metal for a better connection same with g401 ground
Headlights work too just no front signals
Man it seems that you either connected a wire wrong somewhere, or cut a wire. The only thing I can thing of to do is double check each connection. Thats pretty much about the only thing it can be, either that or check fuses and relays. Maybe check turn signal/hazard relay? Idk man, hard to figure this kinda stuff out without looking at it.
It's funny this used to happen to me when I would pull the bulbs out my corner signal lights in my integra! when i would mess with my intercooler or something i would need to remove the signal lights and bulbs and this would happen! the only thing i found to make it work was plug in the bulb and plug it out the socket and give it a good snap putting it back in the corner housing.
ogawa_jiei
Sep 23, 2006 06:10 PM
