Modifying the corner lense?
Old Sep 19, 2001 | 09:17 PM
B2FiNiTY's Avatar
Default Modifying the corner lense?
Is there anyway to have the signal bulb not come on when I turn on my headlights? I want the side marker bulb on only and the signal to flash when I signal. Is there a way?
Old Sep 19, 2001 | 09:20 PM
Mike M's Avatar
Founding Member
Default Re: Modifying the corner lense? (B2FiNiTY)
Use a test light figure which is the (parking + wire) I forget I believe its green
Cut it (leave about 2-3 inches though to make it easier to connect it later on.
Old Sep 19, 2001 | 09:23 PM
GRM Scott's Avatar
25 Year Member
Default Re: Modifying the corner lense? (TypeRmsm)
the pre-98 integras did that cool sequence flash, where the turn signal would go bright in front and turn off the side part, and then would go dim in front and light up the side part...like the gen4 preludes...i always liked that about my GS-R, wonder why they changed it. Maybe rig up a switch so you can turn it to normal incase the man gets on yer case..."what do you mean officer, they're on...are you feeling well?"
Old Sep 19, 2001 | 09:31 PM
Turtle's Avatar
Default Re: Modifying the corner lense? (Aleph)
I think you have gone switch mad you post *****!
Old Sep 19, 2001 | 09:33 PM
Mike M's Avatar
Founding Member
Default Re: Modifying the corner lense? (401-2001)
What about a switch for the switch
Old Sep 20, 2001 | 10:51 AM
B2FiNiTY's Avatar
Can anyone else back up TypeRmsm's answer? I wanna make sure I do this right since I don't know much bout wires.
Old Sep 20, 2001 | 10:55 AM
Chris's Avatar
TypeRmsm is correct.
Old Sep 20, 2001 | 11:02 AM
B2FiNiTY's Avatar
If i cut it how will i connect them back together in the future?
Old Sep 20, 2001 | 11:10 AM
Chris's Avatar
use a little piece of same size/type wire....solder ends back together and cover with Heatshrink.
Or just use solderless crimp connecters...
Old Sep 20, 2001 | 11:16 AM
Splat's Avatar
Collector-o-Guns and Drinker
I've seen an M5 with sixteen switches
Bob#455's Avatar
You don't have to cut it...take a pushpin or needle and you can just remove the connector from the light plug. That's what I did
Old Sep 20, 2001 | 11:58 AM
FBP_1171's Avatar
Default Re: Modifying the corner lense? (Bob#497)
WHY?
[Modified by FBP_1171, 12:58 PM 9/20/2001]
Old Sep 20, 2001 | 12:06 PM
tatty's Avatar
New User
I have an easier solution. You take the bulb out, take some electrical tape and cover the contact for lights on. Easy, and you dont' need to worry about connecting wires later...what i did anyhow.
Old Sep 20, 2001 | 12:11 PM
Bob#455's Avatar
Default Re: Modifying the corner lense? (FBP_1171)
WHY?
BECAUSE I WANTED TO!!!
Old Sep 20, 2001 | 01:20 PM
jonsteR's Avatar
If i understand you correctly and it's a dual fillament (sp?) bulb, then all you have to do is use an electrical tape and put it in the contact point (pin or whatever you want to call it) in the socket that gets the power when you turn on your lights and leave the other one as it.
Acethriller
Lighting
Jan 4, 2014 07:58 PM
soccrplayrgtp
May 4, 2011 10:23 AM
Spracer03
Mar 28, 2008 02:56 PM
amit_b82
10
Mar 2, 2008 08:39 PM
