1999 Civic/ Auto Transmission and engine limp mode
Old Oct 2, 2022 | 11:03 AM
Carsonmcs's Avatar
Icon4 1999 Civic/ Auto Transmission and engine limp mode
This started with the tranny slipping at WOT. I pulled both speed sensors inspected and cleaned (both were perfectly fine) along with the pins on each connectors. After cleaning the VSS and input speed sensor the tranny went into limp mode. Locked in 4th gear, D light flashing etc. I then checked codes and replaced the Singular linear solenoid. Still in limp mode and still has P1768 code along with a new P1753 code TCC solenoid. Also discovered the alternator is not charging, so i tested it and it is perfectly fine. I just replaced the ECM and still no change in limp mode. Computer is also not receiving any data from either speed sensor, but does not throw codes for them. I am stuck and do not know what to do next pls help... Oh also tested all fuses on the fusebox in the bay and all were fine. No idea what to do..
Zauku
Jun 15, 2013 05:50 AM
Twolowpaco
Transmission & Drivetrain
Nov 21, 2012 02:33 PM
badmrb
May 23, 2006 11:20 AM
Carson89X
Feb 18, 2005 09:06 AM
jsw1gga1
Nov 4, 2003 02:25 PM
