Transmission Problems
Old Sep 21, 2022 | 06:11 PM
JackLeeH12's Avatar
Default Transmission Problems
I have a 1994 del sol s model.
Almost everything on this car is original. A few months ago I replaced the clutch, throw out bearing and slave cylinder. When engaged into almost any gear, I can wiggle the shifter side to side almost like it’s in neutral. This has been a problem for a few months now and is only getting worse. Just within the past few days I’ve been struggling to get it into first gear when stopped. It is almost as if there’s some sort of resistance behind it. Sometimes when I get it to go into first gear…. The car tries to stall out even though I give it gas and feather the clutch. I constantly keep checking the clutch fluid reservoir and the level has stayed the same. I know there are things that need to be replaced but I’m not sure where to start. Any advice is appreciated. Thanks
drlagares
18
May 30, 2015 03:46 PM
dragonxiong88
13
Mar 25, 2011 04:40 PM
socal_dsol
Oct 18, 2010 05:44 PM
Leo C
Jun 26, 2006 02:22 PM
