GSR swap stalls as soon as I plug the MAP sensor in.
Old Sep 18, 2022 | 09:38 AM
TheOnlyQueso's Avatar
Default GSR swap stalls as soon as I plug the MAP sensor in.
Hi everyone, hope you're having a good Sunday.
Last night I tried to get my GSR swapped CRX running. I was struggling to get it to run up until a point where I unplugged the map sensor and tried starting it and it popped off and idled fine (other than being 13-14 afr).
As soon as I plug the map in, it stalls out. I managed to get it to start for a second with the map plugged in but I think that's just because it disregards map sensor readings when cranking (I think).
I tried the firewall mounted map from the old D15 with the same results. I don't know if this sensor functions identically though so that may have been pointless.
There are a lot of aftermarket parts on the motor, rywire swap/tuck harness, skunk2 TB, ITR intake manifold, decapped LS fuel injectors from huntertuned, fuel rail, aem fuel regulator. The ECU is a P75 with VTEC added and a CobraRTP.
I guess my next step is to test the rywire harness but I have a hard time believing that would be the cause of the issue.
If anyone has any input it would be greatly appreciated. Thanks.
Old Sep 20, 2022 | 08:16 AM
Aradin's Avatar
Premium Member
Default Re: GSR swap stalls as soon as I plug the MAP sensor in.
MAP and TPS plugs switched?
Old Sep 20, 2022 | 08:27 AM
No. MAP sensor is reading fine in HTS.
I was able to get the engine to idle at around 14.4afr if I adjusted my scalar to like 500 with 0 offset, but it would run very rich if I gave it gas. With stock settings (372 scalar with -70 offset, at least according to HTS) it seemed to instantly force it to go to 20 or higher afr, instantly killing the engine.
I ordered a $40 PLM 4-bar map sensor to try. I hope it's decent as it's really all I can afford.
strafelul
Apr 25, 2022 08:19 PM
oksblue
Mar 31, 2013 03:59 PM
D-Rizzle3
Mar 1, 2008 09:51 AM
mustninty20
Sep 27, 2007 12:22 PM
