Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
Slow Crank even with jumpstart and new starter
Old Sep 16, 2022 | 03:27 PM
Vapor Locked's Avatar
Default Slow Crank even with jumpstart and new starter
Hey all, I'm kind of running out of ideas here, so if anyone has experienced this or has any ideas, I'd greatly appreciate the help.
My brother borrowed my 07 Civic Ex (manual) and it has been sitting for a year or so and it now won't start. It was cranking slow, so he charged the battery and it hadn't changed. We tried jumping it and it still cranks very slowly, one or two revolutions maybe before it stops cranking. Next we changed the starter out with a used but good one, no change. Swapped in a new starter, swapped out the battery with the one from my Si and still no change, replaced the negative battery cables, still no change. Tried jumping it with a jumper battery as well as another running car n no matter what it cranks very slow and then stops. The connections all looked good. I need to get this car running again and am thinking about trying popping the clutch like I used to do all the time with my old Beetle when the battery was low or the starter was sticking. It ran fine before, and has oil in it though it did leak a little since I bought it a couple years ago with over 200k on it.
Old Sep 16, 2022 | 10:52 PM
av911's Avatar
Default Re: Slow Crank even with jumpstart and new starter
Check the starter relay?
Old Sep 17, 2022 | 10:26 AM
Thanks, av911. No, I hadn't seen it and thought it might have been built into the solenoid or something. I'll be checking that once i figure out how to get to it
Old Sep 17, 2022 | 02:03 PM
Well, crap, the starter relay made no difference at all. I swapped it out. Also, I can hear the fuel pump prime, but it doesn't crank long enough for that to matter I would imagine.
Old Sep 17, 2022 | 02:57 PM
av911's Avatar
Is the green Immobilizer light lit on the dash? Maybe not recognizing the key?
Old Sep 17, 2022 | 03:43 PM
No Immobilizer light. It cranks but very slowly and only maybe one revolution before it runs out of juice. I just tried using a jumper battery and a battery cable directly to the positive starter terminal and it seemed to crank a little faster and longer but still no where near like it should.
Oh, also checked and had 12v at the 2 positive terminals of the starter relay.
Old Sep 17, 2022 | 04:34 PM
Ryanthegreat1's Avatar
Voltage drop test for bad ground cables
Old Sep 17, 2022 | 05:11 PM
Thanks RyantheGreat, the test we just did a measurement after trying having already been trying a few times to crank and voltage dropped from 12.8 to 9.7 across the battery terminals while attempting cranking for about 20 seconds. Hmm I don't think I got a voltage drop measurement at the starter while cranking yet. I'll get that next
Crap I guess that's it, 7.0 across the starter while cranking.
Old Sep 17, 2022 | 08:56 PM
Voltage drop from the negative terminal of the battery to the engine block. Shouldn't see more than 1v when cranking. Should see 0v with key on or off.
Old Sep 19, 2022 | 01:39 AM
Ok, thanks again. it's gonna be a few days probably until I can get back over there to check that. I remember the drop was zero across the grounds while not cranking n I replaced all of them except the passenger side one just to rule them out and seeif the was any improvement. If there was, it was not noticeable. I can't remember if we got cranking voltage drop across them though.
Old Sep 19, 2022 | 06:55 AM
Can also do the same voltage drop on the positive terminal to the positive wire on the starter.
It is possible the new starter is junk.
dj-t
12
Dec 5, 2011 06:18 PM
Boarderx192
Jun 29, 2007 06:05 AM
rukawa1one
May 29, 2005 07:06 PM
bamaTeg
Nov 24, 2002 12:31 PM
