Starter or battery problem? Need some help
As long as I dont have to take out any more Metal Gears
My car was driving fine today. I parked it, went into the restaurant to have some lunch. After lunch, I got into the car, stuck in the key, pushed on the clutch pedal, and the car justed clicked one and didn't start. The radio was working fine as i kept repeating this process. It sounded like the starter didnt crank, all i heard was a click and no more. I was able to get a little running start so i popped the clutch and it started. When I got home, I turned off the car, and immedietly tried starting it again, but the same thing happened as above. What the heck is goign on with the car?
Re: Starter or battery problem? Need some help (rukawa1one)
Sounds like the starter motor froze up on you to me. The car SHOULD have charged back up enough to start on the way home, Also it would have died on the way back if the alternator was messed up and your battery was shot. You can try jumping it once to see if its the battery but I doubt it. Sounds very much like a bad starter.
Re: Starter or battery problem? Need some help (nocturnaldragon)
yea def. bad starter... you can take it off and take it to a pep boys or somewhere b/c a lot of those places test starters to see if they are working.
Re: Starter or battery problem? Need some help (alleyezonme)
Yea I forgot to mention that. Good looking out The battery cable way will eliminate the battery tho leaving the same conclusion. BTW they SHOULD test the starter for free.
I'll have to try jumping it before i conclude its the starter i guess, thanks guys.
I always thought that starters gave symtoms that they were going bad, but mine just did it all of a sudden
damn, my car did the same thing today too. but instead of doing a manual running start, i rode my bike to work
damn starters... mine just clicks also, but doesn't crank at all. stereo works too...
JDM As It Gets
12-15-2006 11:52 AM
