B20V missing in vtec
Old Aug 22, 2022 | 04:03 PM
Br0wning's Avatar
Default B20V missing in vtec
Hey guys I’m stumped. I have a b20 vtec with Brian crower stage 2 cams and the car runs fine at lower rpm’s (1000-4500) but once I get on it after about 4500 it starts to cut out really bad and starts missfiring. Got new spark plugs new cap rotor. Upgraded oil pump, new o ring under the cam cap, cleaned the vtec screen, upgraded injectors and 255 walboro fuel pump it’s also on hondata sc300 the tune shop corrected all the timing and said oil pump and silinoid were fine and no issues so This is my last ditch effort to try and get some help on what could possibly be going on.
Old Aug 22, 2022 | 08:25 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: B20V missing in vtec
Was the engine fully tuned ?
If you have good oil pressure and the solenoid is functioning, consider the possibility that your mechanical timing is out a tooth... so check to make sure all timing marks are in proper alignment.
Old Aug 22, 2022 | 11:22 PM
Br0wning's Avatar
From what the tuning shop said the oil pressure is all over the place, the cam gears in line
Old Aug 23, 2022 | 04:35 AM
theYBLEGAL's Avatar
Loved
Check the oil system for solid pressure. Check the vtec system for adequate pressure. Fix leaks. Did you lose or forget to install a vtec locking pin perhaps?
Here is how to test, and may as well verify your valve lash is right.
Old Aug 23, 2022 | 07:29 PM
aw614's Avatar
10 Year Member
Loved
A tight valve lash can cause misfires in VTEC, check the lash and maybe err on the looser side on the exhaust valves to be safe.
Old Aug 25, 2022 | 09:46 PM
Br0wning's Avatar
Here’s my cam timing if that helps. It does look off to me
Old Aug 26, 2022 | 12:05 PM
theYBLEGAL's Avatar
Loved
The photo is arbitrary at best.
Here check it correctly, line up the marks like the guide says.
http://yblegal.net/wp-content/upload...ice-Manual.pdf
Old Aug 26, 2022 | 01:38 PM
Br0wning's Avatar
Cams are shot😞
Old Aug 26, 2022 | 01:57 PM
Chance EG's Avatar
This needs to be fixed before anything else.
Old Aug 26, 2022 | 02:41 PM
theYBLEGAL's Avatar
Loved
Cams are shot😞
Looks pretty normal to me. I don't see any scoring. Just normal wear for a 20yo+ motor. You see scoring?
An emery cloth should clean that up. Any machine shop would call that a micropolish. Wouldn't cost much for a pro to clean them well.
If you are looking at the edges you can ignore the roughness. Your rockers should have pads that never contact those areas of the cam.
JayDMJ
Sep 23, 2016 07:43 AM
Eghatchgsr8
Jun 27, 2016 11:25 PM
JayDMJ
Dec 18, 2015 11:55 AM
xxxmikenicexxx
Jul 27, 2006 07:03 PM
BoM
Oct 2, 2001 05:59 PM
