Cel help (99 civic hx/ex)
Old Aug 9, 2022 | 05:18 PM
Dylan Darcey's Avatar
Default Cel help (99 civic hx/ex)
I have a 99 civic hx coupe, it has the d16y5 block with the d16y8 head, ecu and intake manifold basically making it an ex (done by previous owner). I have two check engine lights, one is p0452 (fuel tank pressure sensor) and p0450 pending(Evaporative Emission System Pressure Sensor/Switch). I replaced all the sensors on the bracket above the fuel tank with ones from the junkyard and got a new gas cap and the check engine lights still come on. I’ve reset the ecu and disconnected the battery and they still come back on after about 20 miles or two days. I was just wondering if anyone has had similar problems or knows how to check for the problem.
Old Aug 9, 2022 | 08:12 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Default Re: Cel help (99 civic hx/ex)
You can try to install a 10k potentiometer in place of the FTP sensor, and adjust it to between 2.4V and 4V until the P0452 code goes away, similar to what is described in post #11 of this thread: https://honda-tech.com/forums/acura-...ltage-1201612/
On a 99 Civic:
Reference voltage from PCM – Yel/Blue wire
Fuel tank pressure sensor input to PCM – Lt Grn wire
Sensor Ground from PCM – Grn/Blk wire
image source: https://quartzcomponents.com/products/10k-potentiometer
There are other styles of potentiometers.
Old Aug 11, 2022 | 02:55 AM
Is it possibly my ecu? My ecu code it 37820-p2p-335 and from what I’m looking at I think that’s the ecu from the 96-98 model and mine is a 99.
ChelseaJean
May 9, 2015 08:20 PM
tyboe
10
Sep 20, 2008 01:24 PM
tweak
May 21, 2003 03:59 PM
