Six check engine light codes! Please help
Old 09-10-2008, 01:41 AM
tyboe's Avatar
Default Six check engine light codes! Please help
Ok, so recently i've been having quite a bit of trouble with my car.
Specs:
97 dx/cx (emblems removed before i purchased) civic hatchback with d16y8 swap. Running a p2p computer.
Problems: After doing an intake manifold swap from automatic to manual i had a CEL for vtec syst malfunction.. p1259 (bad wiring)
While driving around one night the speed-o suddenly went out and the headlights began pulsing from bright to dull.
After checking the CEL codes i now find 5 more codes.
They are as follows:
p1298
p0135
p0141
p0453
p0450
After going to a shop and having it checked out i now have the vtec wires soldered and wired properly to the ecu.
However i still have the CEL code p1259. And all the others listed above.
Upon doing some research on the codes via google i have discovered a couple different options to solve my problems..
The first involving codes p1298, p0141 and p0135
Link:http://hondaswap.com/civic-del...6522/
The solution given is to change the Engine fuse box which contains the ELD. Also removing the bracket under the intake manifold to examine wires possibly contacting the engine block creating a short.
And the second involving codes p0453 and possibly p0450
Link: http://technet.ff-squad.com/code91.htm
The solution here is to replace the gas tank with a tank equipped with an FTP sensor. The d16y8 i have is pulled from a 98 ex.. These vehicles came standard with an FTP sensor.. The cx and dx models did not. Since the p2p computer is from a 98 ex it is looking for the FTP sensor.
My question to you is have you ever heard of either of these methods solving similar problems and what do you think could be causing these problems?
Old 09-10-2008, 12:11 PM
tyboe's Avatar
Default Re: Six check engine light codes! Please help (tyboe)
bump
Old 09-10-2008, 01:53 PM
hazard2o9's Avatar
i had the same problem as u with the fuel tank pressure sensor, pepole i ask here on honda-tech said that civic ex doesnt come with fuel pressure sensor thats y the engine light is on....they told me to swap my gas tank to a integra fuel tank cause it has a fuel tank pressure sensor.....which i never did, all i did was pour some fuel injector cleaner and gas treatment in my gas and it went away ever since....it been gone for about a month now
Old 09-10-2008, 02:01 PM
Relic1's Avatar
check all engine and chassis grounds.
Old 09-10-2008, 05:29 PM
tyboe's Avatar
Default Re: (Relic1)
well i've heard that the sensor doesn't come into effect until after like 8hrs of driving..
Old 09-12-2008, 02:11 PM
tyboe's Avatar
no one?
Old 09-12-2008, 03:53 PM
Pothole987's Avatar
Default Re: (tyboe)
i've heard of something that may cause this, something about wires chaffing against the steering colum or something and it'll eventually stop charging your battery and such.
Old 09-12-2008, 07:41 PM
Burnt Toast's Avatar
Default Re: (Pothole987)
Here is your problem: http://www.hondalac.com/servic...e.pdf
I had this problem also, here is the thread for you to read through. If you tried to use the search, you need to use the RED search option in the upper right part of the page. Then type in your codes and enter. If you do not get anything, click on the ARCHIVE button option to the right and try again.
Old 09-20-2008, 07:29 AM
cueto's Avatar
Default CEL Diagnostic HELP!!
Can you tell me how you checkd your CEL? I have a 94 civic Lx stock, I can not locate the plug and I am unsure how exactly to get the codes!!!!
please help
thanks
Old 09-20-2008, 07:47 AM
Default Re: CEL Diagnostic HELP!! (cueto)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cueto &raquo;</TD></TR><TR><TD CLASS="quote">Can you tell me how you checkd your CEL? I have a 94 civic Lx stock, I can not locate the plug and I am unsure how exactly to get the codes!!!!
please help
thanks</TD></TR></TABLE>
https://honda-tech.com/zerothread/1901557 Look here
Old 09-20-2008, 01:24 PM
riceburnerryan's Avatar
the new peeps just want everything spoonfed.. there is no search i guess...
tyboe
08-31-2008 11:45 AM
DC5 Demon
02-07-2006 09:05 PM
lv6l
10-27-2005 04:01 PM
beeroh
09-24-2004 08:16 AM
MeanGreenEG9
12-04-2002 07:58 AM
Quick Reply: Six check engine light codes! Please help
