No start after lots of tests and parts
93 Del Sol
ECM: 37820P28A51
Engine: D16Z6
VIN: JHMEH6260PS006090
Car was starting slowly, but I could get it to run by spraying starter fluid into the intake. Then one day, that stopped working. I commence to scouring forums. I've tried:
- replacing the battery. It needed a new one anyway. this improved the slow start, but was clearly not the full problem.
- replacing main relay. tried 2 new relays. neither of the new ones or the old one click when ignition is in position i to prime the pump, but if I jump 1 to 7 (in ignition position i) or 5 to 7 (in ignition position ii) the fuel pump runs
- tried all tests in this thread: https://honda-tech.com/forums/honda-...prime-3181753/
- read many other threads looking for clues
- purchased new ECM from these guys: https://www.fs1inc.com/. I've called them and told them it didn't work and walked through all the tests I did. They'll call me back on Monday 8/8.
- tested and cleaned primary grounds - battery, transmission, alternator, thermostat
- tested all fuses under dash and in engine bay, all are fine
- fuel pump runs when power is applied
- CEL does not turn off when ignition is in position ii
The fS1inc.com guys may send me another ECU or possibly take my old one and repair it. But what are the odds they gave me a bad ECU? Is there anything else that could be causing the problem? This is my wife's "fun" car and she's a little irritated that she can't drive it when it's warm and sunny! If another ECU does not solve it, I guess I have to get it towed to a professional, unless this forum can save me!
Thanks id advance.
ECM: 37820P28A51
Engine: D16Z6
Thanks id advance.
93 Del Sol
ECM: 37820P28A51
Engine: D16Z6
Thanks id advance.
ECM: 37820P28A51
Engine: D16Z6
Thanks id advance.
boosh
Sep 28, 2021 05:51 AM
Curlybandit
Aug 10, 2013 04:19 PM
jiujitsuhonda
Jul 23, 2012 10:42 AM
