Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
Adding a resistor to my ELD
Old Jul 10, 2022 | 05:47 PM
Waltermelon's Avatar
Default Adding a resistor to my ELD
I read somewhere that if you are upgrading your sound system in a Honda part of keeping your voltage high is dealing with your ELD (Electronic load distributor, I think). Basically the ELD is responsible for shutting off your alternator when the car thinks you don't need anymore charging. The ELD has no idea you have added extra strain on the electrical and does it regardless. (My voltage regularly drops to 11v for no reason.)
Anyway, I read if you added a 800ohm resistor to the ELD and left it unattached it would solve this problem. Your alternator will run all the time and you will have a steady 14.4 v. Your gas mileage will suffer slightly but otherwise everything will work fine.
My question is, is this a good idea and does anyone know of any problems with doing it? Any experience, pictures and advice is greatly appreciated.
Vtec04
Jun 4, 2017 07:43 AM
curtie94
Feb 7, 2011 11:04 PM
dangercartjason
Classic Hondas
Feb 19, 2010 04:55 PM
ottobell22
Aug 3, 2005 12:06 PM
sesshona
11
Feb 19, 2004 09:51 PM
