Help!! Please help having misfire probems
Old Jun 19, 2022 | 06:52 PM
Ek-chris12's Avatar
Default Help!! Please help having misfire probems
Okay guys I have a 2000 EX coupe with a b18b1 I'm having a problem with it misfiring under 3000 RPM it sounds like a subi and it does not like to stay at a idle without wanting to die I have done a compression test and all cylinders are good. I've cleaned the injectors new cap and rotor, put in a good ignition control module, new spark plugs, new fuel filter. I checked timing marks and it's on time! But here's the crazy part I unplugged the vacuum line from the fuel pressure regulator and it stays at idle just fine only thing is it does idle at 1500rpm! I've been chasing problems for a month now. The car ran fine before this problem I was driving it one day and it just started sputtering out of no where when I push on the gas pedal! Thank you for any info on what this could be!
Last edited by Ek-chris12; Jun 19, 2022 at 10:44 PM. Reason: Forgot to add I did compression test and all 4 cylinders are good
Doug_I
Classic Hondas
Mar 5, 2010 07:27 AM
aznfish
Jun 1, 2009 04:40 AM
layinlowon14s
Mar 26, 2007 11:04 AM
psyonicdeath
Jul 1, 2005 07:25 PM
MintFlavored
Nov 3, 2002 06:57 PM
