Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
Ep3 hesitation when changing gear in vtec
Old Jun 7, 2022 | 12:24 PM
Varks97's Avatar
Default Ep3 hesitation when changing gear in vtec
Hi guys, recently got myself a 2003 type R. I’ve scoured a few forums and no ones really explained what’s going on here and I’ve not had a definite solution. So, I’m having a slight hesitation issue when accelerating in vtec. 1st to 2nd is great, spot on. 2nd-3rd when I get up in the revs and change gear whilst in vtec (~8k revs) release the clutch and straight back on the accelerator I get this hesitation from the car. It doesn’t cut out or feel like it’s about to stall… Only lasts about a second but it’s enough to notice I’m not putting any power down.
from what I’ve read there’s something called a drive by wire? Which can cause this but that’s in slightly newer Hondas? Correct me if I’m wrong
basically Noones been able to give me a definite solution and any help will be appreciated.
the only mode I have on my car are a short shifter and an induction kit but I can’t see that being the problem? Oil level is good and spark plugs are in good condition (will double check this).
cheers
Old Jun 19, 2022 | 12:10 PM
CiViC07HondA's Avatar
Default Re: Ep3 hesitation when changing gear in vtec
could it be a clutch issue, not engaging like it should? or are you just not getting power for a second?
Lightsped
26
Jan 8, 2009 02:09 PM
92eg6
Feb 9, 2007 09:12 AM
an2ny888
Mar 1, 2004 01:04 PM
VTECLuDe96
Oct 8, 2003 08:09 PM
user 996328629
Apr 18, 2003 09:06 PM
