2 items can they be related??
The vehicle in question is a 2004 Honda CRV w/ close to 190K. Original Alternator and Starter. I been chasing an engine Po134 for quite some time and finally got a scanner that allows me to see what the computer is doing at the point where it triggers it: The computer turns off the ground side control to the heater side.
I also bought one of those volt meters that you plug in cigarette lighter and found some interesting results.
Run 1
1. Clear engine code and start car,
2. RPM's are around 1100 when cold
3. Drive car normally
4. Has the car warms up around 3 miles, rpm's are dropping
5. The moment the check engine lights up, the voltage drops from 14.1 to 12.1
6. Is this a fluke or I got to 2 unrelated problems
Run 2
3. Drive car hard, just like you stole it
4. I can maintain the light off for several miles as long as the rpm's are high
6. Is this a fluke or I got to unrelated problems
Run 1
Run 2
Does the scan tool show alternator duty or commanded charge duty?
If it is commanding a high charge duty and the voltage is dropping to battery voltage I would say the alternator is shot.
sorry I should have said is this normal
operation for the circuit to be turned off ?
I am not sure sure if this is normal or not.
The car still has the original alternator w/ 185k so it can also be the problem.
heater circuit can draw more power so makes sense that it would command high charging mode?! Someone knows...
A1218
Honda Accord 2016- 2017
Oct 18, 2021 08:11 AM
Flawlesson24z
May 8, 2019 09:42 PM
kinvid22
Jan 20, 2007 09:17 AM
