Honda CR-V & Element 2WD & 4WD Element & CR-V
changing trans fluid lift procedure
Old May 10, 2022 | 08:22 AM
stretchrunner14's Avatar
Default changing trans fluid lift procedure
Hello and thank you for your time and help....2019 crv lx, Can I just put the front end up on jack stands or the front and rear on jack stands for a trans fluid change.....thanks...
Old May 10, 2022 | 03:29 PM
ajchien's Avatar
Default Re: changing trans fluid lift procedure
Either seems fine for me.
Old May 11, 2022 | 10:02 AM
uDraft's Avatar
Either is fine, ramps are easier. On my older Gen 3, the plug is easily accessible without raising the car. The transaxle in the back you will need it up in the air.
Old May 11, 2022 | 01:47 PM
starchland's Avatar
Ideally level
matsy
Transmission & Drivetrain
May 11, 2022 03:06 AM
jmanuel
Apr 24, 2014 09:48 PM
honda.girl.1991
Jan 16, 2014 08:36 PM
Jordans95si
Aug 27, 2005 05:55 PM
mystikz2002
Acura TL, RL & ZDX
12
Jan 20, 2005 09:22 AM
