cooling
speedfactory race older model custom radiator spal fan
speedfsctory water neck
gplus eBay radiator color hoses full kit
going to use water wetter
little autozone radiator fluid
and a little tap water or whatever
turbo parts / tuning
s300 v3
aem uego Wideband the small slim wideband
mechanical boost
mechanical oil pressure
tial bov 50mm
tial wg 44mm vband
nitro (European) t3 44mm vband full ramhorn
THANKS TO THE HT’s highs cooler and txdragon my plan is for this turbo to make 400whp -450whp. My goal really is to run 10.0-11.99 on 1/4 lol
GTW3476JB turbo .60/.63
vibrant 12810 intercooler
eBay piping custom fitted welded
previously on a small turbo and a mtig log manifd
Made 280/260 with electrical cutout hiccup problems I think dizzy going bad
anyway with this new setup I’m all ready to go
just need to redo downpipe for vband flange
and redo hotside piping
heres pics as of Rnrn
this will be my trial error and questions and what not from now on!
as of rn
i need to buy vband clamps for wastegate to create a dump tube and to mount to turbo manifold
i need to get vband flange weld for the downpipe
weld
and create a good fit for hotside (traction bar problems)
I’ll be ordering some parts to finish up assembly tonight then I can figure out tune!!
but Gsxr tuning from Kenny Sampson!!! Og speedfactory tuner!!
here’s old pics tho before these upgrades ^^
some r still current (non turbo wise)
essentially
log manifold n small turbo
upgraded to speedfactory miniram with a eBay new gt3582 maxpeeding but the traction bar got In the way. Got lucky with a new friend sold me nitro manifold
then the og ht members sold me the Garrett turbo
so The parts list above is current!
There are adapter flanges available to go from V-band to four bolt or five bolt, however they add some space so then the downpipe might not line up with the exhaust.
Your build looks good overall since you’ve already made 280HP, it should be a matter of just getting the boost turned up and retuned. What fuel pump
are you using? Are you on stock sleeves or have you put a block guard or anything? I’d keep it around 400HP if on stock sleeves, which should be good enough for a high 11 quarter mile. Nice Recaro seats too.
That is good you’re close to SpeedFactory for tuning.
