No low beams and high beams driverside
Had wiper problems found out was the MICU replaced with salvage part 2 days found DRL light was on stepped out side with light turn on to find no driverside low beam and high bream is out. Fuses are ok probably another MICU is there a way to wire up the passenger side to driver side without get over voltage or should just replace it with another Known good MICU that I buy from honda. Stuff is getting spendy though. Want to finish building my frank i put in and convert it E85 . Need a answer
dotay
16
May 14, 2005 09:29 AM
