Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
2013 civic HYBRID - Check brake system, check IMA system, check charging system
Old Mar 30, 2022 | 03:48 PM
Jarone's Avatar
Default 2013 civic HYBRID - Check brake system, check IMA system, check charging system
Wife’s car has about 180k and never a problem since new….until she pulled into the driveway today after work.
Three lights came on. She says it’s slower to start the engine too.
Anyone seen this before?
I’m at work and will check it out later.
Old Mar 30, 2022 | 05:06 PM
Ryanthegreat1's Avatar
Default Re: 2013 civic HYBRID - Check brake system, check IMA system, check charging system
Probably due for a new 12v battery. Pretty common to get all those errors together on a Honda Hybrid with a failing underhood battery.
Old Mar 31, 2022 | 10:20 AM
Jarone's Avatar
It was my intention today to buy a new 12v battery and try that out but things didn't work out in my favor, now I'm at work.
I did take a minute to check the codes.
Old Apr 1, 2022 | 08:01 AM
Jarone's Avatar
Car has been sitting for 2 days now. I just checked the voltage with a volt meter and it's showing 12.3v
Battery is almost 4 years old but still holding good voltage.
Old May 28, 2022 | 07:07 PM
Baldog's Avatar
Im having this same issue but It only shows code 61-11
Have you figured this one out? :/ Im afraid of being the hybrid battery any help would be appreciated
Old May 29, 2022 | 06:16 AM
Jarone's Avatar
it was the the inverter, $3000
Old Jun 3, 2023 | 09:50 AM
Hondo47's Avatar
same thing for me, got all the lights and warnings as OP but 611-11 is the only code the scanner is reading.
was it the inverter for you as well?
Old Jul 31, 2023 | 06:57 PM
Larry_Civic's Avatar
Have you tried Rebooting?
As in, disconnect the battery, leave it unplugged for an hour or 10 minutes, I dunno, and connect it back?
Or get a code reader with capacity to Reset the Codes and Reset them, see if they come back
Daleford
Dec 8, 2015 10:49 AM
Robin6
64
Oct 7, 2012 06:45 PM
shortyz
Dec 26, 2002 07:39 AM
