Honda CR-V & Element 2WD & 4WD Element & CR-V
Cylinder 1 misfire in 2002 Honda CRV
Old Feb 28, 2022 | 08:15 AM
Shooter89's Avatar
Default Cylinder 1 misfire in 2002 Honda CRV
Ok so I replaced the spark plugs a while back, I checked the gap etc and replaced with top recommended spark plugs.
About 6-months later the engine light came on with code for misfire in cylinder 1. Replaced spark plug, which had some carbon build up on it. About a week later the light came back on with same code.
replaced all valve cover gaskets including the coil seals too.
Same thing happened again.
Swapped coil 1 with coil 3 to see if that was the problem. Same code came up on same cylinder. Only this time it went away after a day or two, was off for 2-3 days and then came back on.
Am I correct in assuming that it could be a bad fuel injector based on the carbon build-up? That is going to be my next swap!
thanks in advance for any thoughts or suggestions.
Old Feb 28, 2022 | 08:33 AM
NukeNinja's Avatar
Default Re: Cylinder 1 misfire in 2002 Honda CRV
Swap cylinder 1 fuel injector with cylinder 2. See is the misfire moves.
Old Feb 28, 2022 | 08:45 AM
Shooter89's Avatar
great thanks, I'll try that!
Old Feb 28, 2022 | 04:05 PM
starchland's Avatar
Burning oil or coolant?
another good thing to check is the valve adjustment
Old Feb 28, 2022 | 07:17 PM
Shooter89's Avatar
Doesn't appear to be burning oil, coolant also is good and clean.
I was gonna go with the valve clearance next but figured I'd try the easy stuff first before jumping into the big jobs.
Old Feb 28, 2022 | 10:02 PM
DCM1's Avatar
I second the suggestion to check the valve lash. It’s not a huge job, but if you’re unfamiliar with it then it can seem like a big deal. Once you’ve done it a few times you’ll be able to do it in under a half hour start to finish.
Old Mar 1, 2022 | 04:09 AM
Shooter89's Avatar
fortunately I have done it before and am pretty quick at it.
Old Mar 2, 2022 | 06:29 AM
AceSpades's Avatar
Before digging deeper, check the compression
lchavez2117
Honda Accord (2013 - 2015)
May 14, 2020 01:25 PM
Shortyluvsu2808
May 26, 2013 05:40 AM
CUTTERSPOOL
Jun 16, 2009 05:11 PM
crum
Oct 10, 2005 06:42 AM
kinvid22
Mar 15, 2004 09:09 AM
