i bought this h22 swapped 00 si from some crackhead hillbilly 2 years ago for $1500. it had mismatched seats, mismatched wheels. was just in general really poor condition. core support was destroyed. they hacked the floor up for the shifter. It was a total mess. Ive done everything I was capable of doing, on my own. picked up an OEM EM1/CTR grill and lip, purchased new OEM belt moldings and other odds and ends from honda and finally I had the car resprayed EBP by a local collision shop.
click here to check out my previous build
click here for my Instagram
i never planned to go as far as I have, but here we are...
very basic engine, trans and turbo setup Engine
jbre sleeved gsr
81.5x87.2
10:1
stock head
stock cams
supertech springs, retainers, lmas
edelbrock intake
70mm tb
speedfactory fuel rail
fuelab regulator
bosch 2000cc injectors
rosko racing injector bushings
dw inline filter
walbro 450
8an/6an fuel lines (all vibrant, i love their stuff)
wireworx engine harness
tractuff 16an filler necks
scirocco radiatoe
Transmission/clutch
stock GSR trans w/mfactory diff and new bearings
comp twin disc
Turbokit
custom built top mount t3/44mm
pulsar gtx3582r turbo
tial mvr 44mm gate
tial 50mm blow off valve
dual backdoor speedfactory intercooler
custom built 3" cold charge pipe, 2.5" hot charge pipe w/HDI clamps
4an feed, 10an drain
PRL 10an drain flange w/oring (love these!)
3 port boost solenoid
"ktuned" k series shift cable firewall grommet to pass cables through firewall
custom wiring for oil pressure, fuel pressure ethanol content and boost solenoid. using duetsch connectors!
will be tuned on e85 by humble on s300 v3 w/boost by gear. hondata COP w/d17 coils
should be able to datalog oil and fuel pressure as well as e-content.
car is also very basic,
exterior, OEM+
new OEM ctr headlights
oem em1 grill
oem em1 lip
new oem belt moldings
new oem rear glass molding
new oem quarter glass moldings
oem color, nothing fancy
interior OEM+
mtxl wideband, glowshift oil pressure gauge
stock si cluster 162k (prob not original)
98-01 dark grey integra seats, stock rears
suspension and brakes
ksport coils
new bushings throughout
wilwood dpha 4-pot calipers in front, oem in back
stoptech brake lines
complete brake tuck, custom bent lines. prop valve under heater core
wheels and tires are again basic
avid "slips"
nitto nt05 and nt555s
if i feel like it can swap on my ce28's or my starks, but probably wont.
interior
98-01 integra seats
si cluster
mtxl wideband
momo 350mm monte carlo wheel
momo adapter
hybrid shifter
hybrid shift ****
And as I stated, core support was beat to hell! I ordered a new one from Honda for just under $400. I would eventually order a new front bumper as well.
Core support was replaced, so I test fit the front end. It lived up so well. Now the car sat. Probably day for a year or so while I tinkered with customer cars. Finally the car was ready for the paint shop.
I took the car to a body shop I felt was capable, but it day outside for 5 weeks with no windows. Owner finally tells me that it's not likely they'll get to it until winter, so I picked the car and took it to my second option. Dropped the car off, they quoted 3 weeks to paint it, it took them 9. But it wasn't sitting outside in the weather.
Before car web but to paint, I was able to basically mock everything up. I used my blown up GSR block and had and an empty trans case to get the intercooler and radiator where I wanted it. From there I moved into the cold side pipe. Got the clamp ferells welded to the intercooler. 16an bungs welded to the radiator. Tractuff filler neck and thermostat housing moved, made radiator hoses after that.
