Dohc zc engine help
What stock Head stud fit a dohc zc engine I lost one and looking for cheap head stud or for one stock head stud I need the one in the center if Intake side which sit higher then other does anyone know what kind I need I just want something for.now just to see if this engine turn on before I spend money on it or can I turn engine on with 9 head stud
Ok Thankx man I order them but I had a ? Look like they all the same size does that matter cause the one I’m missing is the intake inside center that higher will thr stud work on that spot or do I need to grind some off thr stud or no
The factory bolts are two different sizes: The lengths are 155mm and 164mm. I am not sure how many long ones are needed, but I believe as you have described that it is just one. The part number for the long one is: 90005-PH7-003.
Team Loyalty
Jan 17, 2022 09:17 AM
Ricochet.
Nov 5, 2004 10:21 PM
