96 Civic Fuel Pump Only Primes When Warm?
Old Jan 8, 2022 | 08:03 PM
4g4dcruisin's Avatar
Default 96 Civic Fuel Pump Only Primes When Warm?
96 civic, 5 speed, stock everything.
when turning key to ON, fuel pump doesn’t prime and relay doesn’t click. I replaced with new relay and same issue.
after maybe 5 minutes of leaving key in ON, relay clicks and pump primes, fires right up. Will keep firing up unless I let the car sit for a few hours.
also, I can jump two pins on the main relay connector to manually trigger the fuel pump to prime. This is why I thought maybe the relay.
Not sure what to do at this point.
Old Jan 9, 2022 | 11:06 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: 96 Civic Fuel Pump Only Primes When Warm?
Try another "known good" ECU.
4g4dcruisin
Jan 6, 2022 12:35 PM
oldschoolfever
Jul 1, 2017 04:14 AM
b20hatchek
May 11, 2014 02:50 PM
withouttrouble
Mar 21, 2012 08:08 PM
