B20b4 swap (del sol)no start or crank
Old Jan 8, 2022 | 09:52 AM
chris_42's Avatar
Default B20b4 swap (del sol)no start or crank
I replaced main relay and starter and spark plugs and about to change distributor when it arrives but it just doesn’t crank at all and oil light comes on and fuel still primes but nothing what can I do? Any help would be much appreciated.
Old Jan 8, 2022 | 04:45 PM
punk0mi's Avatar
5 Year Member
Loved
Community Favorite
Default Re: B20b4 swap (del sol)no start or crank
Sounds like the starter solenoid isn't getting activated. Check the small wire that connects to the starter via a spade terminal (not the main power wire from the battery). Make sure it is plugged in. Make sure it gets voltage when you turn the key to start.
Also, make sure your all your engine grounds are attached properly.
Lastly, make sure your battery voltage is > 10VDC.
Preludelearner
Mar 26, 2015 07:54 PM
wongdang
22
Sep 29, 2013 01:21 AM
jachrist
Feb 5, 2010 10:46 AM
wolf95
15
Nov 16, 2009 08:24 PM
Ace0246
13
Sep 3, 2005 12:09 AM
