Performance Build
Yo idk if this is where to post but i have a 2015 Crosstour with the 3.5L SOHC J35Y1 V6 iVtech engine and im trying to increase hp to at least 500. Right now stock im sitting on 278 Stock and am looking for some turbo options maybe even twin turbo but im looking to build this car to perform. Any and all help and advice is greatly appreciated.
P.s I might do a swap for the 3.0L DOHC J30AC that comes in the '21 TLX Type S idk if its a good move tho.
have a look at this thread.
if you put together a similar build minus the high compression and meth injection system you're probably in the neighborhood of 500.
Ryanthegreat1 is right about that transmission, I wouldn't expect it to hold together past 350hp. this is the cheap and easy way to find out. largest nozzle then run it on the dyno until you find the weak link.
