Possible turbine issue
Old Jan 2, 2022 | 12:46 PM
Tuf xsi's Avatar
Default Possible turbine issue
Hey guys so recently bought a turbo (t04e) and manifold combo (used). The exhaust manifold has a waste gate on it but the turbine housing seems to have previously had 1 welded on it, its now shut closed and I'm wondering if it might cause any issues?
From what I understand, is that if the gate on the housing once worked well, then it should be fine now that it's permantly closed because technically its simulating a closed waste gate, right?
Old Jan 2, 2022 | 07:39 PM
highschooler's Avatar
Default Re: Possible turbine issue
I think it should work.
Old Jan 4, 2022 | 03:02 AM
DaX's Avatar
DaX
Loved
Community Favorite
You'll be fine. I would use some kind of locking fastener, or I would occasionally check to make sure those nuts/bolts holding the block-off flange in place are tight.
Old Jan 4, 2022 | 04:06 PM
Tuf xsi's Avatar
It looks like it's got jb weld around the edges but when I take my csr to get the wastegate and intercooler piping done I'll get the fabricator to weld it shut and possibly cut the pipe shorter just to reduce the wasted space.
Thanks for the reply
1sicef9
Jan 2, 2011 06:49 PM
RubenPrelude
Feb 28, 2008 07:34 AM
Boostage
Sep 24, 2007 05:41 PM
00BoostedGSR
Jun 11, 2006 03:32 PM
