Valve cover head bolt
Where can I find these bolts easier. I ordered the bottom bolts. But now I need the bolts on top (circled)
it’s bolt B I got the part number but I just can’t find it anywhere at all. I been googling everything about it in different names but I can’t find it… I’m surprised I found the bottom bolts. Wondering if b series valve cover head bolts would work… or if I can find some oem parts online from a reputable source..
part # 90213-PH3-000
Nut, Cap (6MM)
Thanks for helping me guys. I still have a problem. My valve cover is leaking still ! I’ve replaced grommets, and bolts, there’s no pinching anywhere, I even put a gasket sealant on it and my valve cover IS STILL leaking oil. I looked at the valve cover, there are no cracks at all, also at the head, no damage. I do not know what to do with this valve cover leak. Idk how something that’s suppose to be easy is so hard to take care of…
What brand gasket are you using? I had terrible luck with the blue Felpro gaskets. They leaked, and then they swelled up when exposed to oil, so after removing the valve cover there was no way to get them to go back in. Since switching to an OEM gasket I haven't had any significant leaks (still have minor weeping). I have my valve cover off at least twice a year to adjust valves and inspect the valve train. I re-use the same gasket.
Sorry for the late response, guys. What my problem was I had to replace the bolt a and bolt b, I ordered from the dealership. They got it ready for pick up in 2-3 days. I ordered a new valve cover. Old one had some kinks on the oil cap area, causing it to throw some oil.
thank y’all for helping me
Joshgb
Mar 26, 2018 01:32 PM
crxaddikt
Sep 19, 2002 10:08 PM
