Honda CR-V & Element 2WD & 4WD Element & CR-V
2005 CRV shifting problem
Old Nov 30, 2021 | 10:16 AM
ClemsonYankee's Avatar
Default 2005 CRV shifting problem
P0752 Shift Solenoid A Stuck On.
Multiple questions
Is the solenoid behind this cover?
Anyone have experience changing this?
Is there enough clearance to change it without adjusting the transmission?
Does the cover have a paper gasket?
Old Nov 30, 2021 | 06:56 PM
Allchokedup's Avatar
Default Re: 2005 CRV shifting problem
I had same issue, would actually take off in second. I replaced solenoid and it helped for awhile but eventually had to start shifting on the column.
I have read many times if your trans fluid hasn't been changed in forever, you shouldn't change it. Not sure the bro science there but I see it often.
I think your going to need a new trans in a couple thousand miles
Old Dec 1, 2021 | 09:33 AM
Northernlightz's Avatar
Might as well try replacing the inline atf filter to see if that makes a difference. It runs off a cooler line on the bottom side of the radiator.
hondoman1
Transmission & Drivetrain
Mar 6, 2014 08:03 PM
slwh22accord
Honda Civic (2001 - 2005)
Oct 20, 2006 06:02 AM
sohc prelude
Feb 26, 2006 07:26 PM
DarkShadow
Oct 7, 2004 05:24 PM
hb_racer
10
Mar 14, 2002 02:36 PM
