92 civic wont crank & wont prime fuel pump
Old Oct 11, 2021 | 12:27 PM
L8Apxr's Avatar
Default 92 civic wont crank & wont prime fuel pump
I have a '92 civic that I am trying to bring back to life. Its a B18c swap.
I made a boneheaded mistake and put the battery in backwards (its not as dumb as it sounds, battery was relocated to back, and both terminal wires were black from last owner).
It blew out the 80 amp battery fuse (which I've replaced).
The car now has lights, power to gauges, etc, but I dont hear the fuel pump priming, and I get zero reaction from trying a start. it is not cranking, nor even trying to crank.
I am actually trying harder to get the fuel pump to work, since I am trying to get some old and bad gasoline out of the fuel lines from the tank (already drained it, and put 5 gals of fresh 93 in there).
Any recommendations? Fuse 24 is intact, if that makes any difference.
Thx!
Old Oct 11, 2021 | 12:52 PM
L8Apxr's Avatar
Default Re: 92 civic wont crank & wont prime fuel pump
by the way, I remember I vacuumed up a whole bunch of moldy old blue plastic pieces from my floorboard, so I am guessing that is the clutch safety switch.
I guess I'll try to track one of those down. seems consistent with the symptoms.
Old Oct 11, 2021 | 04:32 PM
L8Apxr's Avatar
I jumpered the clutch safety switch and I got the starter solenoid to make clack loudly, but no cranking. starter could be bad.
I still can't get any fuel pump love though...
Old Oct 19, 2021 | 03:22 PM
Farcere's Avatar
Have you tried a main relay out of another Honda? Can get them online for cheap if you can't borrow one
VicVarron
Sep 2, 2021 04:36 AM
dannyg510
Dec 1, 2017 10:12 AM
Jkim81
34
Oct 9, 2008 09:39 PM
GOTNOS
Oct 9, 2004 09:57 PM
