Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
Location of Engine Coolant Temperature Sensor?
Old Oct 6, 2021 | 11:15 PM
jmath1's Avatar
Default Location of Engine Coolant Temperature Sensor?
Hello,
Recently had the clutch replaced but came back with an the engine light light on. Scan saids its the P0118 Engine Coolant Temperature (ECT) sensor circuit high input. Code comes back after clearing. Engine temp guage shows full after about a minute after starting the car so isn't accurate.
Can anyone help with the location of the sensor? It's an 07 HONDA CIVIC SPORT Manual FD2 4 Door Sedan FWD PETROL 2.0 litre, K20Z2 I4 16v DOHC VTEC MPFI
Photos:
Old Oct 7, 2021 | 06:54 AM
Ryanthegreat1's Avatar
Default Re: Location of Engine Coolant Temperature Sensor?
Likely the sensor was damaged getting the transmission in or out, the sensor is right above the bellhousing.
Old Oct 7, 2021 | 07:33 PM
jmath1's Avatar
Wow.. couldn't have asked for a better reply than that. Thanks so much!
Old Oct 7, 2021 | 08:32 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
The photo above is actually from an earlier version of the K20A... your ECT sensor is slightly higher and more rearward on the same end of the cylinder head in the K20Z2. It is less visible because the coolant housing, which contains the upper radiator inlet and the rearward facing heater hose, is on the same end of the head and covers the area circled in the photo above.
Old Oct 7, 2021 | 08:56 PM
Oh fine, this image then.
Old Oct 8, 2021 | 08:54 PM
JRCivic1's Avatar
10 Year Member
Community Builder
There you go !!! PERFECT.
Old Oct 9, 2021 | 02:34 AM
jmath1's Avatar
Haha thanks so much to you both. Much appreciated!
Old Nov 30, 2021 | 02:32 AM
jmath1's Avatar
So I found the temp sensor location and looks like the wire has been pulled out from the connector. How to I reconnect the wires to a connector like that? Also, which wire is the upper wire and which one is lower? (it's a green w/ black stripe and a red w/ white stripe). I have included some photos. Thanks again!
EDIT: So I managed to remove the inner connectors that crimp on to the wire with some pick tools. But if anyone knows which way around the wires go, would be much appreciated. Or will it damage anything if I get it wrong the first time?
Old Nov 30, 2021 | 06:43 AM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Due to the wire colors, your Australian Civic's terminal wiring may be similar to the US Si terminal wiring for the ECT sensor 1.
That is a female connector, so the terminal numbering is based on the wire side of the connector.
Old Dec 1, 2021 | 07:08 PM
jmath1's Avatar
That worked.. Thanks so much really appreciate it!
Old Jan 23, 2024 | 10:07 AM
madicos's Avatar
Hey guys.
Does anyone know what the part number is for this sensor part ?
It would be for a 2007 Honda Accord LX 2.4.
Old Jan 23, 2024 | 08:33 PM
JRCivic1's Avatar
10 Year Member
Community Builder
The part number is 37870-PNA-003.
dohcvtecpower
Sep 30, 2010 05:11 AM
tunes12
Sep 18, 2002 08:33 AM
JDM Accord
Aug 26, 2002 01:28 PM
