D16z6 into a 2000 Civic EX
Old Sep 20, 2021 | 05:35 AM
nightrider93ex's Avatar
Default D16z6 into a 2000 Civic EX
What’s up HT...bought a D16z6 block in great condition from a friend to put into my daughters auto 2000 EX due to the y8 taking a dump. Anyhoo so I switched the IM along with injectors from the y8 over to the z6. Also switched over the oil pump over to the z6 from the y8 to keep the CPS.Kept the distributor housing from the z6 but put all the internals from the y8 distributor. So pretty much justused the bare block of z6 and everything else is y8 to try and keep it obd2b withits p2p ecu. Problem is...it’a starting with a nasty misfiring idle then just shuts off, then try again and no start. Same cycle of starting on and off with nasty shaky misfiring. Only one code is being thrown which is the knock sensor. We have complete spark going. Getting fuel aswell. Tested all the parts from the dizzy, changed out to some spare obd2 injectors I had here, I’ve checked the timing on crank pulley/cam gear over and over. Compression numbers are 125-130 across the board. I’ve gone to the extent of waking up the neighborhood one morning disconnecting the header from Cat thinking it might be clogged haha. I also tried to by pass the CPS. Could it still be a timing issue? I think I remember seeing somewhere that the timing marks on their crank pulleys are off by a few degrees? Any ideas and help would be awesome thank you.
Old Sep 20, 2021 | 10:44 AM
Spaceturtle917's Avatar
Default Re: D16z6 into a 2000 Civic EX
The timing gear and cam are both notched on the z6 for 16 degrees base timing, as well as the harmonic balancer having the timing marks at 16 degrees. Y8 base timing is 12. You need to swap to the y8 harmonic balancer for timing (or use a timing light with adjustable timing and go off the tdc mark). But if you try to time it with the z6 cam and cam pulley you'll find the dizzy is either maxed out, or doesn't go far enough. To fix this you'll need to swap both the y8 cam and y8 cam pulley. Then set the ecu into timing mode and time it properly at 12 degrees.
Old Sep 20, 2021 | 06:35 PM
What if I add the cam gear and harmonic balancer from a y8 and not the cam? Can I get away with trying to tone it like that? Isn’t the cam profile not too far off from each other?
cityofcaterpillars
Engine Management and Tuning
Aug 7, 2016 10:44 PM
eoris__ej1
Mar 6, 2014 02:42 PM
eoris__ej1
Jul 9, 2013 09:10 AM
eoris__ej1
Jun 26, 2013 12:09 PM
powrachute
Dec 15, 2009 09:57 AM
