Fuel Pump not priming. 90 Civic ee9
Old Sep 16, 2021 | 01:25 PM
Nes@lisbon's Avatar
Default Fuel Pump not priming. 90 Civic ee9
Hey guys/girls, so, i have this problem where i used to put the Key position ON, i ear the clicks at the main relay x2, and the fuel Pump priming for 2/3 seconds ( not everytime). Manage to start car with some dificulty but it ran.
now, the battery broke completly, change for a new One and now.... Cant ear the fuel pump.
Ive measure the voltage at the sending unit (i think) under the rear seat, i get 12v on green/white, but on Yellow/white, doesnt get any when it should have for priming.
What should i do to get the fuel pump to prime???. Have a new pump by the way.
Also have the fuel indicator stucked at fuel, even knowing its almost empty.
Thanks in advance
Old Sep 17, 2021 | 09:46 AM
honda.lioness's Avatar
Default Re: Fuel Pump not priming. 90 Civic ee9
I would do the checks of the main relay described in the attachments. The main relay is located under the panel near the driver's left knee, not far from the hood release. I would also take the case off the old relay and examine the solder joints. Photos of bad Honda Main Relay solder joints appear at:
https://techauto.tripod.com/mainrelay.htm
​​​​​​MarkLamond.co.uk - PGM-Fi - Main Relay
youtu.be/X5Qp-ToR8KA , starting at about 5:29
Still another approach is to grab a few main relays from a salvage yard and try them.
The main relay Honda OEM p/n is 39400-S10-003. Alternatively get the Mitsuba RZ-0132. Many Honda years and models use this same main relay.
File Type: pdf
File Type: pdf
Old Sep 17, 2021 | 10:47 PM
Nes@lisbon's Avatar
Beautiful, thanks.
ill give it a try and let you know soon.
Up up.
Old Sep 22, 2021 | 06:12 AM
Nes@lisbon's Avatar
So, got it fixed, i knew the fuel Pump was good, so i checked for power on the connector under back seats, and came 1 time, and the other 10x no power.
runed a test to the main relay, using the directions that where given to my here (THANKS A LOT).
found that there was no continuaty in 1 of the relay tests. Took it out, Open relay, check solders, some almost unexisting, some dry. Grab my tools and using other guide given here i manage to make new soldering on all the terminals.
now works every time.
Thanks for the assist, and Also previous threads, as the sharing of knowladge in here.
UP UP
pappasmurf
Nov 11, 2024 07:43 AM
Freemananana
37
Sep 23, 2015 04:32 AM
hatchBK4life
Aug 2, 2010 05:11 PM
93FlatBlackHatch
Dec 30, 2006 03:22 PM
