Civic 1997 1.4 90HP loses power uphill (at about 3000 feet altitude and up)
Old Aug 29, 2021 | 12:36 PM
Mike85's Avatar
Default Civic 1997 1.4 90HP loses power uphill (at about 3000 feet altitude and up)
So, I have a 1997 Civic hatchback with 1.4 petrol engine. It has 90 horse power. Uphill, especially in high altitutes it loses power, I can barely get uphill with normal speed, I mostly have to use 2nd or 3rd gear. People pass me by, I dont blame them : )
I know that this engine has low power and torque out of the factory, but could any other mechanical malfunctions be affecting this loss of power more than expected ?
Could the brakes be binding, O2 sensor malfunction (wrong air/fuel mixture), I have put new spark plugs in (NGK), new spark plug leads (Bosch), new engine oil, engine oil filter, air filter.
Lets say theoretically, If I put a 1.5 VTEC engine inside (engine swap), it has 115 HP, then it should go uphill easier ?
I have an option to buy a 1.5 engine for 600 EUR but its not economical on this car. I wouldnt get back the money I put in if I sold the car.
The more rational way is to sell this car the way it is, and buy a factory stock 1.5 Civic, or buy another car altogether. I think I would like to buy a Lexus (maybe IS200, or IS250).
Then there is also the Civic 1.6 VTI model, that was the fastest one in Europe, but also the 1.8 exists, but I think those were mostly for Africa, thats what Wikipedia says : )
Thank you for any suggestions on which parts on my car I should check to be sure that something isnt slowing down the car uphill unnecesarily.
Also, this loss is mostly with two people onboard, and I have alot of things in the trunk.
I will try to go on a test drive with just me onboard, and without the stuff in the trunk : )
Old Aug 29, 2021 | 04:37 PM
Chance EG's Avatar
Default Re: Civic 1997 1.4 90HP loses power uphill (at about 3000 feet altitude and up)
If the brakes were binding, you would smell/hear them.
Can't tell you if something is wrong with your engine without knowing I guess exactly how much weight you have in the car and how steep the hill is. In general, you should be able to maintain speed while going uphill.
A 1.5 engine would not have a noticeable power increase.
Old Sep 19, 2021 | 12:09 PM
Mike85's Avatar
I have put out some things from the trunk, now the car is lighter and it seems to go uphill easier. I keep it in 3rd gear and it can keep up, atleast it doesnt slow down, it slowly accelerates. So im happy with that.
ricoredbeat
Honda Civic (2006 - 2015)
Sep 8, 2018 05:50 PM
nonoyc
Oct 9, 2017 04:07 AM
Unseen Racer
Dec 23, 2008 04:39 AM
neverhadahonda
Oct 11, 2006 10:05 AM
blulude92
May 4, 2003 04:05 PM
