Radiator hose issues on mishimoto rad with d16 ek
Old Aug 3, 2021 | 03:09 PM
acdrew's Avatar
Default Radiator hose issues on mishimoto rad with d16 ek
I have heard that a b series radiator hose will solve the issue of fitment I am having with the lower hose on an aftermarket radiator. My question is off what model car the del sol or 2000 civic si etc?
Old Aug 3, 2021 | 07:08 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: Radiator hose issues on mishimoto rad with d16 ek
What is the part number of the Mishimoto Radiator that you bought ?
Old Aug 3, 2021 | 09:45 PM
acdrew's Avatar
MMRAD-CIV-92X
x line radiator
Old Aug 4, 2021 | 04:28 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Are you suggesting that the radiator necks are LARGER in diameter than the upper and lower radiator necks on your D16 engine ? If they are, you have the wrong radiator. The larger "B" series necks, like those found on the '99-00 Civic Si or the '94-97 Del Sol DOHC, use a hose that is 1/8" larger inside than the SOHC Civics. If you try to use the larger hoses that fit the DOHC radiator, they will likely leak when you try to "pinch" them down to get them snug on your engine.
candyman206
21
Aug 13, 2009 12:33 PM
hybridevul
Jun 16, 2005 07:03 AM
shadykit
Aug 31, 2004 12:46 AM
wdskuk
12
Jan 24, 2004 09:38 AM
Judah
Aug 13, 2003 10:41 AM
