Honda CR-V & Element 2WD & 4WD Element & CR-V
2000 CRV crank but no start
Old Jul 19, 2021 | 07:28 PM
Brian R's Avatar
Default 2000 CRV crank but no start
Hey everyone I'm at a roadblock with my 2000 CRV. It currently cranks but doesn't start. I had no sparks on the spark plugs so I went ahead and replaced the entire distributor unit thinking that would fix the problem. It didn't. Still no spark even with the new distributor. Any suggestions on where to go from here?
Also fuel pressure is good and I hear the main relay click with the keys get turned.
Old Jul 20, 2021 | 07:29 AM
KiNGDEE206's Avatar
Default Re: 2000 CRV crank but no start
bad new dizzy / bad wiring connection on dizzy olug
bad grounds
maybe bad compression / low compression
did it ran before and now its not
did u check if firing order is correct when new dizzy installed
ive had a car work
then stop working
turns out somehow grounds just stop getting connectionso i sanded all frounds to metal and it worked
rkpatt
Sep 12, 2017 05:25 AM
20sir00
65
Apr 7, 2010 03:25 PM
BOMBCRU
12
Dec 4, 2009 06:54 PM
r-6
14
May 9, 2009 05:30 AM
