Help: 94 Civic stalling when slowing down
Old Jun 29, 2021 | 07:22 AM
Pim's Avatar
Pim
Default Help: 94 Civic stalling when slowing down
I recently started getting a issue where when I slow down for a red light or taking a corner the engine will stall on me. It didn't happen when I got the car 3 weeks ago but the day after unplugging the battery to install a subwoofer the problem started. I've already unhooked the sub but the problem still persist.
I've also tried an idle relearning proces but I don't even know a 94 civic does that. Starting the car is a bit rough but once its running it runs pretty good and won't stall most of the time. No CEL in the dash either, when it does happen I can just hold the clutch and start it again with key. This is my first car so I'm new to all of this. I did find a loose connector close to the battery but I can't find anything about that and whether or not it has to be plugged in, you can see it in the pictures.
Model: Honda Civic DX EG3 1.3 L D13B2
Thanks in advance!
View from the upperleft portion of the enginebay
close-up at the connector
Marcin Olczak
Nov 16, 2016 05:04 PM
KingJames37
Sep 7, 2014 06:16 PM
Civicnewbie123
Feb 18, 2014 12:44 PM
gucci3838
Nov 14, 2010 06:23 PM
