Radiator fan being weird
Old Jun 10, 2021 | 04:39 PM
Aaron Fluegge's Avatar
Default Radiator fan being weird
I have a 98 civic ex, the relay is brand new, the relay plug in has continuity to battery, fusebox, ground, and radiator fan, the radiator fan is good, but it doesn't turn on even with jumping the switch, any ideas on what else I need to test?
Old Jun 10, 2021 | 06:22 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Default Re: Radiator fan being weird
Have you checked both under-hood Fuse No. 57 (20A) and under-dash Fuse No. 17 (7.5A)?
There should be power at Fuse No. 57 at all times. Fuse No. 17 should have power with the ignition switch in the ON position.
When you jumped the fan switch harness connector (located the thermostat housing), did you turn the ignition to the ON position (car not running)?
You can also pull the radiator fan relay from the under-hood fuse/relay box and test for power at the fuse box cavity terminals. Out of the four terminals, one terminal is for power (coming from Fuse No. 17) and should be hot with the ignition switch in the ON position. Another terminal (coming from Fuse No. 57) should be hot at all times.
Old Jun 11, 2021 | 08:25 PM
After more continuity testing I do have power to 2 of the terminals with it switched to on, 1 with it off, the fuses are all good and one of the posts go to the fan and the other is grounded, should one be grounded?
Old Jun 11, 2021 | 08:40 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
One of the terminals for the relay should have ground if the fan switch was jumped.
I previously asked, when you jumped the fan switch harness connector (located the thermostat housing), did you turn the ignition to the ON position (car not running)?
Old Jun 12, 2021 | 08:23 AM
The one is grounded no matter what. Yes I did jump it with it in the on position, nothing happened
Old Jun 12, 2021 | 09:50 AM
tech8's Avatar
Global Moderator
Loved
Community Favorite
One of the relay terminals should only be grounded when the switch is jumped. Is that what you meant?
Old Jun 12, 2021 | 11:24 AM
The one under the 12v constant is always grounded whether the keys are in it or not, I believe that's the one that goes to the radiator fan, would that be the problem?
Old Jun 12, 2021 | 12:25 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
The terminal under the 12V constant (hot at all times) is the line to feed the power to the radiator fan motor (once the relay coil is energized and the relay contacts close). That may be okay for now, we can circle around back to that after you try the next test.
Try this, with the relay inserted back, unplug the connector to the fan switch (located at the thermostat housing). Use a spare piece of wire and insert one end into the harness connector cavity terminal with the green wire, and touch the other end of the spare wire to chassis ground. If the radiator fan now turns on with the ignition ON, then it means the ground wire going the the fan switch has an open (break).
Old Jun 12, 2021 | 01:27 PM
It does start when doing this, so I just have to trace that ground wire to find the break?
Old Jun 12, 2021 | 01:34 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
The ground wire goes to G101. For non-CVT, G101 is right next to it (the photo should say non-CVT). For CVT, G101 is near the air box.
Old Jun 14, 2021 | 05:01 PM
Thank you, I meant the wire that was supposed to go to the fan, I'm not sure why I typed ground, but the fan wire was broken where it splits out of the big wire loom.
Rafe Altschuler
14
Aug 11, 2015 04:10 PM
thisdamnhonda
21
Feb 26, 2012 09:47 AM
jarchul2
Sep 18, 2011 01:45 PM
limit
Dec 30, 2008 01:28 PM
